Is the alternator charging? if not you have a problem with the engine speed sensor, if the PCM doesn't get a signal from the ESS it doesn't know the truck is running. Check the gap between the ESS and the engine damper quick easy way to set the gap is to use a business card between the ESS and the damper.
