2 stroke burn test
2 Cycle Oil is much higher in BTU's and also lower cetane rating. As you can see the fire burns slow and long. Where just a small dash of PS burns quick and smokey. This is the cetane booster in PS products.
Nice to see the oil was cleaning up the mess that PS left behind. Really though you should be mixing both of these in there proper ratio and then do the burn test.
