Ok Gang...
I'm going to produce a write-up on how to replace an ignition switch and lock assembly for a 2nd Gen truck. More to follow soon. What happen was I took the 96 Dodge into town and load it with fuel brought it back home. Put it away. Later on realized I needed to bring in firewood for the night. So I went out fire up the truck and backed into the wood shed and shut it down. Loaded up with wood in the bed and tailgate. Hopped back in the driver seat turn the key and shock to feel the ignition switch snap internal and the key rolled over without resistance. No ignition, no start. I played with it for quite a little bit and figured out if I pressed the key inward just a bit I could get the ignition turned on. Now I pulled the start relay and jumped between 30 and 87 and got it started. Got the firewood move to the main house and unloaded. Pulled in the garage and shut it down. I can tell you the mechanical part is functional because the key unlocks the steering wheel but doesn't turn the switch for power or start.
  • Replies 3
  • Views 10.8k
:doh:
Well I made a few mistakes. But still come to find out I need the lock too. Basically you need a T20 Torx screwdriver. Remove the 3 screws in the bottom of the column. Remove the tilt steering release knob. Remove both plastic covers.
DSCF6779.JPG.5998976f357a98d995046f1fe20
DSCF6780.JPG.520678944e3841a99b220a2cb5d
My screw up was I misplaced my security bits and found later after doing this next step. I took a center punch and broke the security pins out of the center of the Torx screws. So you need either a T20 security bit or take a center punch and break the center pins out.
DSCF6781.JPG.9854589eb361b019a47708da55f
So what you need to do is remove the locking screw from the switch.
DSCF6786.JPG.e439b79fe76bf4c338e90942bb0
My misfortune is that the lock assembly is also damaged. So I've made a phone call to the local NAPA store to find out the lock is $85 bucks. None in stock. So I found the lock cylinder on RockAuto.Com for $34 shipped.
DSCF6783.JPG.f66264afcd78a98019738f03306
DSCF6784.JPG.8ca60772fe3f83d161945ae0645
Can you reused the key cylinder or are going to have use a new key? The wife's Saturn lock went out and we replaced with a cylinder keyed the same as the old lock.
I don't have the original keyed lock anymore it was replace once before already. As for the new one its going be here on the 18th so I've got a entire week to wait.
