I just got done pulling my 5th wheel for about an hour and when I stopped I noticed that there was a good amount of coolant splattered down the underside of my truck. As far as I can see it is not coming from the radiator or any hoses. It is wet on both sides of the motor and not mostly down low. My question is if the water pump was leaking would it leak down inside the front cover and come out the bottom. It is very hard to tell where this is coming from.
