Wii not Start & low input fuel pressure
You can remove the cross over tubes with a thick bladed screwdriver. No need for the special tool unless you just want it. Unless you have removed the tubes and injectors I would suspect shot o rings on the tubes. They are easy to replace.
Thanks I'm doing the work this weekend.  Hopefully the new return valve that came in today will solve the fuel delivery problem.  The truck was running at ~16 psi.  So, I don;t thank that would cause the valve to stick.
