No Power but with a story!
30 gallon per hour is what was stock.
I doubt it is a fueling issue if PSI is holding at 10psi.  the vp44 will fuel well as long as it has positive pressure, longevity is another story.
I would pull the battery cables for 30 minutes, do an apps reset, then go out and drive the snot out of it.  Then come back and read codes.  I am still thinking vp44 is to blame.
do you have someone local you can swap pumps with?
  • 5 months later...
