2001 24 valve Vin #7 no start
16 hours ago, ItzReckless said:
The pins are getting 12 volts why hot wire it
By hot wiring it you can eliminate the ECM and pin point it to the IP.
How are you just now checking the fuel filter.  That has been suggested by this forum before.
Because it was new when I drove off lot v I believe running it low the day it died probably sucker all the trash up that was in it , I literally had the truck 1 day off car lot , new lift pump filter and all , so when I did change it , I did notice the old one was to clogged , but see yesterday I started vehicle let idle a second and put it in reverse it died down,  oh well it's at mechanics,  he thought it was vp44 so I guess we will see , mine probably just needs to be flushed honestly, but I'm sure whomever gets my core charge will do that
