ECM fuse 42 power both sides of post
Cjchap
I have made new developments in this electrical issue. I pulled all the fuses on TIPM and tested the panel as I put them in one at a time. When testing B+ from ECM to fuse 42(one side) I got power coming from ECM to test light when I plugged fuse 6 and 11. Which means a short somewhere but where? I've looked over these wires a million times and re did the grounds til shiny. Any help is greatly appreciated. Thanks!
New developments...  The circuit for fuse 6 is for the air bags, fan, wastegate and vist(?). With the key not even in the truck the fan is showing 5volts, the wastegate is showing 12.7-13volts. The continuity through the solenoid is 10.2ohms. Would this be a issue with Tipm? Anybody? Anybody?
It's junk. Short of me putting in a new clutch and wastegate solenoid I am lost on this. I did one of those ask me mechanic websites and the guy was lost. I broke it all down from A to B for him and it didn't help. That's pretty bad when a girl knows more about trucks!
Is there wiring schematics for individual fuses? I'm looking for the diagram for the fuse 11 circuit. And maybe fuse 6 circuit. Trying to find a manual is proving impossible.
