Vbulletin/Wamp Server/Big Dump Questions
Mike I sent this to you in a PM but figured this forum could use the activity and perhaps someone else may benefit from it so I reposted it here. I am playing with the 3.0.9 verson of Vbulletin. I opened up the upload folder, then install folder, control A, copy, then go to the wamp folder, then www folder, then install folder. Am I correct so far?My question is do I just highlight the files in the wamp install folder, delete them and then paste the new 3.0.9 files into the wamp install folder? Then I need to change the config.php.new to config.php?Open the config.php file with word pad.change database to test.savethen go to browser an type in localhost/install/install.phpI guess the question I should ask before I do any of this is.....do you think the current Vbulletin 3.5.0 can upload the SQL file with big dump?I am gonna need some help with big dump. I have very little understanding of what and how it works.
Good luck, with the new forum, sucks you have to start over. I will be there as soon as you get it going, I still visit the dark forum, cause I made friends with alot of these people, but I don't communicate with the enemy :nono:
