Ok guys as some of you know I've had lots of trans issues with my 5600 and was going to swap a 4500 in but after search cand find what I need so I'm look in to maby repair the 5600 which will require having the bell housing repaired but to have the machine work done I need to know the correct spec of the in put bearing hole so it can be machined to fit correctly.
  • Views 1.1k
