High idle and vp44 throwing codes
- Replies 9
- Views 3.6k
Me78569 4 posts
abner99 4 posts
william keagle 1 post
Ok so yesterday I installed mopar1973man high idle kit on my brothers 02 dodge cummins 2500. I followed instructions black plugs go to coolent temp sensor and white plugs go to iat sensor. The iat sensor was not a easy as i though to get too. Next plug the white plug through the fire wall to see put the chip in and plugged it in. Grabbed my scan guage plugged it in to see if everything changes it did. What my brother noticed was white smoke bad. Looked up sure as you though check engine lights on. Looked at codes p0118 engine coolant temp circuit high input. P0113 air temp sensor circuit stays above 4.5 volts. And the worst one P0216 injection timing control circuit. Now I don't know if i bumped any of the other connections that may cause the vp44 code when my hand was down there. Keep in mind it has a FASS fuel on it and it runs 15-18 all the time. And the truck only has 60k on it also he just drove it 300 miles this weekend never had a problem till the other day when I put the high idle kit on. I don't know if this is an easy fix or not. I tried to clear the codes no luck. Scan guage said no response. So I unhooked the battery's and turned the key and lights on hopefully to reset the ecm and get rid of the codes. Don't know what's going on really hate to see him spend 2500 this weekend. I honestly believe I hit something I wasn't suppose too. Any help would be nice thanks.
Edited by abner99
