- Replies 8
- Views 5k
Gil2264 4 posts
Mopar1973Man 2 posts
AH64ID 2 posts
I've been around this block before, Which comes first, the puck or the fooler. Here are some diagrams to explain my theories. also, I'm thinking of trying to add a smoke switch, but I seem to be getting two stories 1. the signal voltage INCREASES as boost pressure increases. 2. the signal voltage DECREASES as boost pressure increases. It would also seem that having a Boost Fooler between the "Smoke Switch" and the ECM harness would eliminate the need for a resistor inline with the switch as the fooler should keep you boost signal from getting out of spec.thoughts, theories, b!#@#*$ or complaints welcomed...I have a thick skinA correction on the diagrams: Ignore anything about a smoke switch on Diagram 2, its not in there. I copied pasted and edited the notes from a later page.I would try to make my smoke switch connections on the boost fooler as 1. It has the easiest access to its wires. 2. It is the easiest and cheapest part to replace. [ATTACH]1259[/ATTACH]
ECM Wiring Theories.pdf
