NV4500 Countershaft question
- Replies 10
- Views 4.9k
Mopar1973Man 5 posts
Akaiser21 3 posts
NIsaacs 2 posts
Hey everyone,
So where do I start.. So about 30,000 miles ago I had a transmission built for my truck since my last one imploded. This transmission has never "felt right." The problem I'm having is as you probably guessed it 5th gear loss. What keeps happening is I keep losing the countershaft retainer (snap ring.) This is a 1999 dodge and I do that the thicker version of this snap ring. I have replaced this 4 times now. Which is getting expensive due to gear oil prices. I have had just about enough of this failure. Has anyone found a reason why this happens? What I have checked is 5th gear nut tightness, splines and just the usual over look of everything there. What I haven't checked is end play. Not real sure how to correct this if it is end play. Im hoping to tear into this this weekend if I can get all the parts in on time. On the verge of swapping this for a g56.
