Front axle u joint
9 hours ago, Ed ke6bnl said:
My newest tool for this procedure is the super  rivet gun I have with a bit that is about 1 in. diameter with a bronze piece on the end. a couple of blast with the rivet gun and the stuff just falls apart.
Love to see a picture of it :drool:
On 8/24/2018 at 11:24 AM, Bar GN said:
My 99 has the typical power steering growl. I had a 98.5 that did the same thing and I swapped the fluid with ATF+4. I wanted your opinion on it and if there was an easier way to fluid swap.  I vacuumed the fluid from the reservoir, filled with ATF, ran it, then repeated the process until I thought I had mostly new fluid.  Ran it for a couple of years with no problem and was noise free. Thanks for amy input.
this is so powerful if you use it with it not against the object it Flys out past the spring
