1999 no start
So a couple months ago I get in the truck and no start. Only relay clicking. So, using forums to trouble shoot my problems, I ordered Larry b’s over oversized contacts. A few weeks of working lots of overtime and rainy weekends went by and finally got decent weather to take on the job. Installed the parts and what do u know, still no start. I’ve swapped fuses and relays so that’s no the problem. Is it possible that the neutral safety switch has gone bad? All of the threads I’ve read, people say they have reverse light problems with the switch. Is this a hit or miss with the reverse lights giving it away or could I have a problem elsewhere? I’m tired of having to raise my hood to start my truck every time I go somewhere. Any help would greatly be appreciated.
Get a test light or a volt ohm meter and a jumper wire
 Test for 12 volt at terminal A/brown wire at the starter motor when the ignition switch is in the start position, if voltage then starter motor/contacts are bad.
If no power at the brown wire for the starter motor then:
At the starter relay test for power all the time at pin #30.  If no power at #30, check fuse #2/30 amp.
At pin #86 check for power when the ignition switch is turned to the start position. If no power at pin #86, check ignition switch for power at  yellow wire, if power then check power at jumper yellow wire to yellow/red wire.
Ohm test pin #85, should be near 0 ohms in park or neutral, if not check wire to trans mission and test neutral safety switch.
Edited by IBMobile
