What's everyones thoughts on using a trickle charger/ battery maintainer on my truck with the quadzilla hooked up? I know it says if I am jumping off I need I need to unhook the quad. Y'all think I'll be ok to leave it hooked up?
  • Replies 5
  • Views 1.5k
  • Agreed, you're good. On my diesels I always wire up a permanent trickle charger under try hood that charges the battery any time I plug the block heater in. No issues with the quad.
  • Mopar1973Man
    No issues here 2 / 6 Amp charger never bothered the Quadzilla.
I only have a 4km commute to work. So even my diesel Jetta, with the draw from the glow plug cycles on a cold day, it doesn't keep the batteries fully charged. The trickle charger is key.
