Tilt wheel actuator
The tilt wheel on my 2004 3500 is no longer working, it’s stuck in the all the way up position. I have watched a couple videos and know it’s the plastic part on the column that is broken. I can’t find the part anywhere? Can anyone shed some light on this?
  • Replies 2
  • Views 2.4k
Have you googled the part number?
  • 1 year later...
 Insert a screwdriver up underneath the ignition and push in a spring loaded vidmate pin until you can wiggle the key+ignition out and place to the side. The electronic switch is on the left side of the column and has a couple quick disconnects and a couple screws. Just swap and put it back together.
Edited by Kasey00
