Looking for Staff Members
I have a custom CAN bus device (particle photon + CAN transceiver) plugged into the IHS bus on a 2018 Ram 2500. I'm attempting to find the codes to preform actions like:
door lock/unlock
mirror retract/extend
start/stop engine
I see all kinds of codes come across the bus, but have not zeroed in on exactly which ones I need. Does anyone have access to documentation on what the IHS codes are that can share?
My purpose is to make my own remote control system (particle electron) instead of paying XM Guardian $250 a year for it.  I figured I own the vehicle so I should be able to make my own electronics to talk to.  I also was hoping to add functionality to my device like automatically retract the mirrors when I press lock or other similar items.
  • Replies 4
  • Views 4k
I dont have codes for the truck, but are you able to use something like terra term to log what is on the bus?
Yes, have a bus probe running. There is a ton of traffic on that bus and it's quite difficult to isolate the single commands I'm looking for.  I suspect what is happening is there are a lot of "acknowledge" CAN messages in response to the code I'm interested, lock unlock all doors.
I'll keep searching.  Maybe I'm close and just need some more focus time to zero in in the right ones.
Datalog a bulk of it.  Make sure to do the commands at set intervals a set number of times so you can isolate better.
  • 6 months later...
Can your probe or logger support external triggers? Tap a switch or a door lock motor (with some protection circuitry of course) and then look at the messages that occur around that time. Also try something similar but inject dummy message on external trigger event or even repeated at fixed time intervals. Try disconnecting nodes like the radio and instrument panel too.
