vacuum connection or windshield washer connection
The vacuum and washer are seperate. Just had cowl off and disconnected the washer under the cowl on the left side. I did not pay any attention to where the line ran. But it would not surprise if it was on the left headed towards the resevoir along the fender.
The vacuum could be leaking any where. If it is all original I would start at the pump and follow it and replace any bad fittings along the way. Does you ac/heat blow out of the dash vents?
Edited by dripley
