Stalling Truck.
Can’t seem to find any answers so I’ll ask you guys. I have a 98 Ram 2500 24v Cummins automatic tranny. Have problems with it going into drive and stalling no problems with reverse. But when I engage my torque converter lock up switch while switching into drive I have no problems. So could that be a torque converter problem or a problem with the switch.
  • Replies 2
  • Views 1.4k
Un hook the mystery switch from the wire between the transmission and the PCM and see what happens.  If you have a good lock up clutch in the torque convertor the engine will stall if it is locked up when stopped.
