My profile explains everything. I am a “diesel dummy” but need a little help to finish diagnosing. I want to check the harness from the ECM to the injector pump. I see where it connects to the injection pump then the harness goes into a main loomed harness. I have probably over looked the ECM but where is it so I can check the connector and pins. Any pictures would be a great help. Thanks
  • Replies 2
  • Views 1.2k
