[FIXED]1997 Engine Speed Sensor
- Replies 6
- Views 7.2k
The_Jackale 4 posts
dripley 1 post
IBMobile 1 post
Hi guys, I bought a broken truck! Now Im also fairly good at testing electrical components which is the only reason I laid down 3800 bucks on a 241k mile Truck. Oh and Diesels sound sexy :D and will pull my future projects easily.
So I didn't have much time to figure out the issue on it. But the symptoms are, No tach, no speedometer, no lights(wait to start, check engine ect) and the trans was said to be in 2nd, topping out at 30 to 35. And also the coolant temp was not working (but I think that is on a different line electrical circuit, will confirm). Im going to buy a new coolant sensor just in case that one is bad, because I thought it was a direct connection (sensor to cluster)
Just for fun on the test drive, I left the the crankshaft position sensor unplugged from the front of the motor and The speedometer was working, wait to start was working and the trans felt like it went to 3rd but no over drive (because no tach)
Safe to say that the sensor I unplugged was bad? It had continuity across pins 1 & 2, but not reversed, i figured a good one should have continuity across both sides. Also my meter fell and broke (new age crapsman) so I was not able to continue to test last night once I parked the truck at my brothers.
Now to get this sensor, napa has it for 180, but its two days out, dealer is 350 and 4 days out.
Edit. Ordered 2 sensors, one from amazon, one from napa. Im curious if the 23 dollar ones works! Its not the gas one either.
Edited by The_Jackale
