Torque Spec for Hub/Bearing Assembly
Hey fellas, about to replace the hub/bearing assembly in my '01 2500 2wd.  I thought I've read that the new axle nut going on should be 185 ft-lbs.  But I've read another source that it should actually be 280 ft-lbs.  It said 185 is for 1500s and 280 is for 2500/3500s.  Is this correct?  Or just internet folklore?
I just borrowed a loaner 30-250 ft-lbs torque wrench from AutoZone.  If it's indeed 280, I'll need to find another source for a higher capacity torque wrench.
  • Replies 2
  • Views 1.5k
  • The FSM calls for 280.    Do you have access to the downloads portion of this site? The 2001 FSM is in there.  Hub.pdf
Hub.pdf
Crap, yeah.  I have a copy.  Didn't think to look in there.  Thanks!
