Oil pressure gauge reading 40psi all the timel
I have a 2001 24v and it will read 40 psi of oil pressure weather its running or the key is just turned to the start position. I might add that it still reads 40psi with oil pressure sensor unplugged well.  I have tried a good know cluster and it does the same thing. I've cleaned all grounds and checked them. Anyone know what it could be?
3 hours ago, dripley said:
You might try checking for codes and see if maybe the sensor is bad. Do you have the 3 wire sensor or the one wire switch?
I have the 3 wire sensor. The only codes I have are P0251, P0252, P0253
4 hours ago, dripley said:
Well those are VP codes that I am not familiar with. Did you use a scanner or the key trick?
Maybe a short in the wiring? I think any info I could give is just speculation.
I did key trick and a scanner same codes on both. i traced the wiring and the wiring looked good. cleaned both the plug and the sensor side.
