Turbo removal
I got everything disconnected and the 4 bolts holding the turbo to the manifold loose and the turbo still won’t come off. Any ideas what I’m doing wrong?
Edited by Jans28
  • Replies 5
  • Views 2.5k
can you snap a picture?
might take a light tap with a hammer to seperate the turbo from the manifold.
I’ve give a couple taps with mallet doesn’t even wiggle
does it look rusty?  you are %100 sure everything is disconnected?
A little rusty not to bad. The only thing I haven’t full disconnected is the exhaust pipe I loosened the clap but haven’t taken it off
do you have something like a plastic putty knife?   Iwould try and get that between the flange and see if it comes undone.
