New Smarty S-03 question
I'm new to the Smarty, just got one.  For initial install I disconnected my Edge EZ and reconnected the factory plug.  The programming went smoothly, including the tire size adjustment (factory 265/75R16 to 255/85R16 -- 32.75").
Questions:  In the future should I disconnect the EZ to change SW# and is it normal on initial ABS adjustment to show current tire size as 00.00" ?
Also, to be clear --- Even SW# with Edge EZ and Odd or Even SW#  Smarty alone?
After ABS adjustment it shows current tire size as 32.75" and the 2 #s indicating currently vin locked to my truck.
Thanks for any info, Joe
Edited by Joe_Pool
To add information
  • Replies 1
  • Views 1.3k
don't stack these 2 boxes one or the other.
you can technicaly stack but htere is no point.  both boxes do the same thing, both boxes max duration and I would say the edge EZ does a better job with timing.
I would run the edge ez over the smarty.
Edited by Me78569
