- Replies 2
- Views 1.5k
wil440 1 post
2ndgenLorenz 1 post
Just installed a new to me (Reman) VP44 after my old one went out completely. During the install I took out the factory lift pump which was mounted on the block since I already have an airdog 100 on the frame. As well as replacing push rod gasket. Blocked off mounting bracket for old lift pump with a big block chevy fuel pump block off plate (Mr. Gasket #1516) frees up some space and adds a little bling lol. So original lift pump and fuel filter are completely off truck. I go to start the truck after purge all air out of injector pump as well as injector lines. Ive done this before a few months before after new fuel filters but i definitely feel like more fuel was put out during that event than the current event I am dealing with now. Memory could also be a little blurry since the truck hasnt ran in around 2 months. SO the trucks starts smoothly but idles somewhat rough. Idle is @750 which isnt abnormal compared to idle when it was running. You can throttle all the way to the rev limiter if you wanted to but as soon as you let off throttle it stumbles then shuts off. It will stay idling for days. You can press accelerator till 1200ish and slowly slowly let down and it will stumble then go back to idle. Currently do have a fuel pressure gauge, waiting for one to ship to see if it is possibly lift pump but the pump starts as its supposed to. Any comments or tips are much obliged. 98.5 Dodge Ram 2500 5.9 Cummins. 152k miles. Auto 2wd. Air dog lift pump. 5inch turbo back. BHAF.
