Donaldson upstream spin on screen
- Replies 1
- Views 2k
dripley 1 post
Popular Days
I use the squeeze clamps like you buy at Lowes or HD to clamp at the AD when changing filters. They work pretty good.
I added this today while home recovering from Wuhans.
The filter is rated 95%, 140 microns, per SAE J1985 test. Pretty cheap off of Amazon and a bunch of filters cross over, so shouldn't pose a problem traveling. https://shop.donaldson.com/store/en-us/product/P552203/1553#
The base is a standard cheap WIX 24770 universal unit. I drilled and tapped the frame 5/16" NF.
I wanted to put a shut-off valve on the tank side, but decided I can just pinch off the hose when the time comes.
Since I removed the "sock" in the tank when the Draw Straw went in, I needed some protection for the lift pump. I searched a 100 micron filter that would fit this filter base, but couldn't find one. Originally I had purchased 25 micron filters for this base, but decided that was too fine - I'd rather change the under hood filter more often!
Edited by LorenS
