- Replies 9
- Views 2.2k
WARDEN 4 posts
Mopar1973Man 3 posts
guesswho512 2 posts
new to site and diesels. i have a 99 2500 4x4 , ctd with an edge ez. the truck has never died but will not start. lift pump shows 14 lb at hwy speed. chk engine lite came on but goes off every time i re-start it.auto zone check shows no codes. from other fourms it appears i could have a bad crank shaft pos. sensor. i have bleed the fuel lines and get plenty of flow but i do not know at what pressure. any help or suggestions would be appreciatted. thanks in advance
