DAP Give Away and Deals-- Free combo--See Details --Injectors, Governor spring kit, DV, AFC Kit, Valve Springs + Retainers
EVERY $5.00 SPENT ON ANY GEAR BELOW WILL GET YOU ENTERED INTO A GIVEAWAY FOR ONE (1) OF THE FOLLOWING ITEMS:
1. 6.7L Nozzles up to 300% with free install, balance, and flowsheet
2. DAP Screaming Eagle SX-E Turbo up to 72mm with turbine housing
3. Dodge 5.9L Cummins DAP Reman 50hp or 100hp Injectors
4. Quadzilla Adrenaline for iPhone or Android, Valve Springs, and Up to 7x.014 injectors
5. 3k/4k or 5k Governor spring kit, Delivery Valves, AFC Kit, Valve Springs and Retainers, and up to 5x.018 Injectors
915513
Save up to 20% off DAP Products!
915515
Overstock Clearance List over $400K in stock ready to ship!
  • Replies 2
  • Views 1.6k
  • dieselautopower
    dieselautopower
    Comes with about 50 shims https://www.dieselautopower.com/diesel-auto-power-24v-injector-pop-off-pressure-shim-kit-24vshim
Cool, do you sell shim kits for vp44 truck injectors. I got mine few years back from you set at 320bar but I'm pretty sure they have settled down. I don't have that many miles on them, maybe 20k so no reason to do anything different other then reset the pop. I'm just getting things lined up now so I have everything when time comes. In process of building a pop tester from a floor jack now, seems to be popular option. If you don't sell shim kits maybe you could point me in direction of who does. :thumb1:
