Thinking I have a boost leak
So I was pulling a heavy load, about 21k and I kept having to back out of the throttle and down shift to keep temps down. Still had plenty of HP but couldnt use it. I noticed it was smokyier than usual, boost is still 19.50 and water temp would climb a little. I looked in the articles and found Michaels air charge rig. It says Cummins Service Products 3824556, searched and no luck. Who is recommended to order from? Thanks
Breather tube? Thatd be crankcase pressure Id think.
Quick google ‘cummins boost leak tester’ I made mine out of 4.5” hole saw plastic part. Put a fitting where the drill bit went. Regulated shop air to it and spray hoses, intercooler, etc with soapy water.
No codes? Air filter clean? If getting at least 19# from MAP?, may be fueling related.
