- Replies 6
- Views 945
LorenS 2 posts
Andyba20 2 posts
Mopar1973Man 1 post
IBMobile 1 post
Popular Days
Not that my opinion counts for much but when I do mine I just plan to follow Mike's article. A $30+ gasket with proper cleanup and careful tightening of the bolts should last a good long while. Now,
One draw back that I see is if the cove needs to come off there is only one source for the oring where the gasket is produced by several manufacturers. If that one source for the oring goes out of bu
If they won't send one you can measure the OD of the o-ring material and make one out of o-ring 'cord'. Just a dab of RTV, etc. will seal up the ends come together. Put the seam at the top of the co
I’ve had a small slow leak from the Tappet cover for a long time. My plan was to wait until my VP bit the dust and do everything at once, but my VP keeps humming along and the leak has gotten much worse over the past 2 months. I’m thinking about getting the billet Tappet cover from Keating (they are local to me). The reason why is because folks seem to have a higher success rate with the billet covers, and I really don’t want to have to do this twice, especially in the winter. Mike’s write up on replacing the gasket is great, but I’m not a professional mechanic like Mike is. Am I being too paranoid, or is the extra $200 worth getting the billet cover and increasing my chances of a successful replacement?
