For Sale - 2006 Dodge Ram 2500- Flatbed for long box bed Winch bumper Flat Bed for Long Box 3rd generation Cummins Tootlbox are included with key I have a flatbed for 3rd Generation dodge Cummins. This flatbed comes with a gooseneck hitch already in the bed. The winch bumper is part of the set. Tootlbox have a key to lock and unlock all box a single key. There is rust starting and electrical will have to be sorted out on your own.
Price: $1,000.00
Just a heads up if you have a 3rd Gen and happen to have a weak connection or on connection on the grid heater power wire it can and will pop the grid heater light and chime as well just like a fuel rail issue. If you pop the hood and don't see any fuel leaks then proceed to get to home or safe place. Get your code reader out and check I'm going to bet there is a code for grid heater performance. Once the problem is fixed and the code cleared the light will remain off. In my case I've unhooked it back in the summer time be I was having a charge issue for the batteries and forgot it was unhooked. No hard starts. Funny part is the light tripped after 30 miles of driving and the engine was at full operation temperature which was weird it trip the grid heater. That makes me ask does the ECM command grid heat while you drive as well?
