40 minutes ago, Mopar1973Man said:
Turn the ignition on engine not running you should see 12V at the tap wire.
I did this but with the key off and it was showing the 12 volts so I’m probably good then. Thanks
Nope...
Wire is not attached to the tuner. The wire must be attached to the pump only. There should only be 12V with the key on engine off.
Your most likely seeing the tuner not the VP44 tap.
14 minutes ago, Mopar1973Man said:
Nope...
Awesome thank you
