- Replies 8
- Views 1k
IBMobile 3 posts
Andyba20 3 posts
Mopar1973Man 1 post
Great work! 1 post
Popular Days
I see @IBMobile already helped you. Here is another drawing that may help.
Red to battery power and terminal 30 Black to terminal 85 and ground White to terminal 86 Signal wire for fan motor relay to terminal 87 Do not use green and blue wire This w
Should work fine . That's why there is a ground wire on the switch. You can always make a mock set up to test on the bench with a 12V power supply, a 12V battery will work. Test it before mounting i
I decided to ditch the thermostatic switch on my auxiliary trans cooler with fan and wire a switch into the cab instead. I got cute and ordered a push button switch with a fan symbol and blue LED backlighting. Can anybody tell me (or draw on a napkin) the best best way to wire this to a relay? Should I be using a standard Bosch 5 pin relay or something different. The wires in the pic are as follows:
Black-negative
Green-closed
White- normally open
Blue- normally closed
Red-positive
