98 12 valve cummins no bus, need help please
I have an in cab meter thats in my switch panel for lights its at like 14.7v when running without lights but im going yo disconnect it when i put the pcm in and see if it gives me any response before hooking everything back up. When everything was working it was at 14.5 i think
Infinite continuity between PCM and ABS Pin 29/30 on C3 PCM and Pin 3/7 on ABS and i checked pin 29 to 3/7 and 30 to pin 3/7 just to be safe and nothing
I put the pcm back in this morning i have it just sitting with on screw holding it loosely for now i turned the key and the OD light isnt on anymore i have the ESS un plugged im gonna purchase a new one and gap it when i get a chance but the WTS still is staying on very curious
So i unplugged and plugged the pcm
C3 in a couple times and OD light came back on im wondering if maybe the pcm isnt getting good connection should i use and grease or anything
You can use dielectric grease, but I don't think it will help your situation.  The dielectric grease primarily helps keep out moisture and reduces the likelihood of oxidation on the pins.
I would carefully inspect the multi-pin connectors for any spreading of the the female terminal and inspect for any wires that may be partially pushed back inside the connector.
- John
My diagram shows pcm 28 to ABS 10 for CCD- . Pcm 30 to ABS 3 for CCD+.
Double check and verify your ohm meter and test leads are working by touching them together.
20240317_105747.jpg.24162a5eca27062434ee34362b80a6e8.jpg20240317_105729.jpg.b63769becf73a933d7b1ee3843bfeac1.jpgOpen up the large bulkhead connector and check the 3 twisted pairs of wires. Look closely at both mating connectors for bent pins or spread sockets. Lightly tug each wire and make sure they are locked in to the plastic good.
See photo.
Will do i should be home for a but after today its outage season so work is pretty strong atm. Ill pull that plug and see whats what and check my continuity
Sorry for the gap between replies i checked those pins continuity is 0 ohms. I pulled the connector didnt see any spread pins or anything wires all seem connected good into the plastic. Im not sure what else i can do. This summer ill be pulling the dash and motor to put in a 24v and all wiring modules etc. is there a way i can run cruise control and ac without the PCM until then or no?
