- Replies 8
- Views 2.2k
jlwelding 4 posts
Tractorman 4 posts
A month ago I started having surging and idling problems. I checked all the usual, fuel filters, pressure and everything in check. At hwy speed you can feel it surging in fact at all speeds of course at over 2500 rpm not so much. If you set the cruise control it goes away. I can watch my throttle on my adrenaline and its fluctuating up and down when using accelerator. At idle at a stop it will go as low as 500 rpm and Ive watched it climb as high as 1800 rpm. The apps was about a year old so I thought that had to be it.Put a new one in and roll along here for a bout 100 plus miles and the new apps starts doing the same thing again. No codes except the grid heaters which ive disconnected. If I turn off my addrenaline on my phone is that good enough or do I need to disconnect under the hood to test if thats the problem? With out codes its a crap shoot. I talked to Dap just because all my parts, fueling is from them. Airing it out with them we both are leaning towards ECM or connection. Timbo has not gotten back to me after leaving a message. What is the name of the guy in Florida who works on ecm's?
