Posted (edited)
Are you sure that it's plastic?
The only components internally that have any kind of plastic like material, is the oil pickup tube inlet screen, and the shift fork pads, but that chunk of material doesn't look like it's from those internal parts.
Can you just grab them with a pair of long needle nose pliers, or a 3 finger grab it tool and pull them out through the drain hole?
Edited by 01_Cummins_4x4
39 minutes ago, 01_Cummins_4x4 said:
What's this for? To order parts? This is the 2nd transfer case I've put in it. Shelled out 2 DLD's before I got ahold of a DHD. I've got another pickup screen that will work. I'm just stumped on how it happend. I know that I had the screen in the slots when I reassembled after doing the rebuild.
Some things just don't make sense.
