- Replies 4
- Views 1k
YeaImDylan 2 posts
Tractorman 1 post
QuadRunnerJake 1 post
Hey all, title says most but will go into more detail.
sometimes on startup, the engine will start, then die for half a second and come back on. Like if you were to turn the key off while running and quickly turn it back on. This happens occasionally and then a few weeks ago, it would start and then die after a few seconds. It did this a few times before it was just cranking. Finally got it started and it ran fine. This has all occurred after my o Reilly vp pump replacement … and I’m definitely worried it’s the pump. Any insight is appreciated!
