Welcome To Mopar1973Man.Com LLC
We are privately owned, with access to a professional Diesel Mechanic, who can provide additional support for Dodge Ram Cummins Diesel vehicles. Many detailed information is FREE and available to read. However, in order to interact directly with our Diesel Mechanic, Michael, by phone, via zoom, or as the web-based option, Subscription Plans are offered that will enable these and other features. Go to the Subscription Page and Select a desired plan. At any time you wish to cancel the Subscription, click Subscription Page, select the 'Cancel' button, and it will be canceled. For your convenience, all subscriptions are on auto-renewal.
- Replies 32
- Views 1.7k
Mopar1973Man 16 posts
Ltk 15 posts
Royal Squire 1 post
We were right, the harness itself was wired incorrectly. IAT and ECT plugs reversed. New harness arrived and problem solved! 3 and 6 both work with correct values displayed.
Yes sir you can. Just key on and click the switch through the different modes and report back the values seen.
Hey Mike, I contacted Quadzilla Monday and they are sending me out a new PCB board and switch. I will keep you updated on how that turns out. They will send me a wiring harness if that doesn't correct
Did This Forum Post Help You?
Show the author some love by liking their post!
Hey guys, I have installed the new Quadzilla high idle box (3 cyl/6cyl) sold by DieselAutoPower Mike developed years ago. When I hook it up as it says (IAT sensor and Coolant Temp sensor) I get the following codes and the unit does not work.
I have verified both sensors are in fact working as well as the grid heater relays are both operational. When connecting them back to factory configuration and clearing codes, those codes do not reappear and everything functions normally with no further codes being thrown.
Any idea what I could be doing wrong?
Truck is programmed with a Smarty S03, 3 cylinder idle is active and does work properly with outside temperatures.
Thanks in advance!
Logan Kendrick
606-794-3951
