Need to put a new thermostat in  my  truck , 1998 5.9 V8 Magnum,
 it appears someone has been in it before and appears to have probably lost one of the housing bolts and used a longer bolt as one is spaced up about 1/2" or so.. So if possible before i remove them i would like to know what size the factory thermostat housing bolts are so i can have them when i replace it. I've found a few results online for thermostat housing bolts but nothing that is a verified fit.
Thanks.
That was exactly what i needed, it showed the bolts in the break down and gave the description of .312"-18x.94
so if my 'ciphering is correct it is a 5/16-18 that is 15/16" long.. so just under an inch long. And the MOPAR number of 06034549 which so far is showing up NLA wherever i've looked online. But this is a huge help, thank you.
  • Current Donation Goals
    • Raised $20
