Expansion plug seeping
Thanks for your reply. I replaced the plug once last year and put a non harding sealer around the edge. It still had some seepage then. I'll install it this time without sealer like you suggested.What did you use to install your plug? I made a jig to pound the plug into block without going to far. My first try I knocked the plug into the water jacket and had to use a magnet to retrieve it.
Ok...(My Bad) I thought this was a first time run. :doh: So there is something wrong if you replace it once and it coming back with another leak... So at this point I would inspect the hole for damage. Clean it really good and look closely. Like in my mind to get it to seal I would wipe a coat of silicone in the hole. As for installing normally go for flush then quit... Which plug is this?
