Injector Virgin
Robvg
Boss wanted me to quit screwing around and change the injectors. I've got just about everything removed except the injectors and tubes.The instructions I found say you have to loosen the two bolts holding a bracket to the back of the head. Looks like a pain in the butt- I haven't tried getting back there yet. Is there just not enough room to pull the tube out without doing this?
Nope, that one's not a problem. There's one bolted flush to the back of the head- just behind the rear injector.
Well, I was able to crawl back there and loosen the bolts on that bracket. It looks like there might not have been much room to pull the tube out and probably not enough to get a torque wrench in there.
Injectors are out and sent to be tested.
Injectors were all bad with one worse than the others. Having them rebuilt because no one but the dealer has any in stock. Shops have been waiting for 6 weeks and are "hoping" they'll start to show up in two or three weeks.Found the same thing on the Internet- "On Backorder"
