Got my raptor 150 and quadzilla chip and have a few questions before install first one I have a short bed and to install the raptor it looks to me I have to mount it on the outside of the frame is there any problems doing this and the other question is looking at the fuel lines on the tank witch one is the return line and witch one is the feed now on to the chip I understand everything but what wire you tap on the vp 44 thanks in advance
Ok... 2 issues
[*]As for mounting outside the frame rail be aware of the debris path from the front tires. Is stones and road debris going to hit the pump and filters? If so you might build a shield to protect them.
[*]As for tapping the VP44 I would suggest you use a stealth plate to do it. Then you have a weatherproof connection, no damaged wires, and most VP44 vendor won't even know the wire been tapped.
i have a long bed regular cab and I was unable to find a suitable spot inside the frame rail.... no filter since its a raptor so I wasn't as worried about the exposure.
Looking at the lines coming off the tank what one is the return and what one is the feed
doesnt matter, with the raptor 150 it is highly recommended to install a draw straw. the stock lines are too small to push 150 GPM I believe the feed is near the middle close to the driver side though.
Fuel line that is bigger is the one going to the pump and smaller line is return. But as far as that goes 1/2 inch big line kit with draw straw sounds like where its at to me with that big of a pump.
