MAP sensor replacement
I recieved code PO238 & now need to replace the map. (99 24 valve stock) any special tools or tips on doing this, just a socket-size ect. Thanks
  • Replies 4
  • Views 4k
Thanks for the quick reply , any idea where to order a new sensor . I guess this is the problem the truck runs fine will it hurt anything to still drive it with the code till I get it replaced , cleared it but it comes back.
It will run like a dog... The fact is as long as the code keep coming back the engine will go to limp mode and defuel heavy. As for replacement sensors it would be a good idea of check with a Cummins dealer first because parts store are a bit high in price for the MAP sensor typically.
Thanks, guess I will get that swaped-out ASAP :doh:
