Timbo Apps
Ok I was going to have a friend help in stall this but he is as reliable as rain atleast around here,and we are in a drought. LOL Oh and he works for the sheriff dept. LOL LOL Can anybody help with this.I have read instructions but :confused: and it seems you need two people?
  • Replies 4
  • Views 3k
I would tap the ECM lead and find out what the voltage is to ECM. While the DVM is tapped to the lead and your watching the voltage twist the sensors slightly up or down to adjust the voltage. It does help to have the screw semi-snug. When you hit your mark lock the screw down tight watching the voltage. You done...
Got it installed and no help,it does lug better.They say it helps that. Ok here we go again ,I hooked a scanner to it and we have no cam sensor reading according to my friend. And of course I allready replaced it about 5 days ago. What would cause no reading besides a bad plug?
