Probe GT clutch
Blueox01
Working on a 95 probe GT,clutch pedal won't return fully,I can push the fork back against the slave to get it to return. My question is there a spring to pull the fork back or is the throw out bearing just not sliding on the input shaft freely?
Is the master cylinder hung up or damaged causing the pedal to hang down?
After further inspection,I can push back on the fork to bring the pedal up.The best I can figure it must be in the clutch/throw out bearing/fork:shrug:
