Brake Pedal???
The adjustable pedal assembly on the 06 Mega-Cab has a lot of slop, so much that the brake light switch stays activated alot. Anyone else seen this issue?
  • Replies 4
  • Views 2.6k
I have a 04 with the adjustable peddles and they work the same as they did when new. Not sure how or if you can adjust them but the system is just a screw drive system. So I would think there should be an adjustment on it.Don
Seems to me the brake light switch would move with the pedal. Sure you don't need to adjust the switch itself?
  • 3 weeks later...
Could the pic you posted have anything to do with the brake light being on :smart:
Nope, this is the whole brake pedal having side to side play and not releasing the brake light swich
