OBD II port... sporadic readings
Today I hooked my computer up to my truck and when I viewed the live data values (RPM, VSS, ECT, IAT, etc) with my truck idleing the numbers were jumping all over the place, for example the VSS would read 0 then 68 then 136 and all over the place with my truck just sitting there idling. So something is wrong somewhere in the truck because I tried connecting to other vehicles we have and everything works like it should with the OBD II cable and software. I'm not even sure where to start in trying to find the problem but right now I'm kind of thinking it may be a ground wire somewhere :shrug: but I have no clue what wires to start checking
  • Replies 3
  • Views 2.2k
Being all communication is on the CCD Network that where I would start... http://mopar.mopar1973man.com/cummins/general/ccd/ccd.htm Also be aware Dodge has a really weird com speed...
The CCD data bus system was designed to run at a 7812.5 baud rate (or 7812.5 bits per second).
hmm now I think it may just be my software and the strange baud rate, although it had been working a few months ago :shrug: but I noticed in the software's console window it was automatically detecting that the truck uses a baud rate of 115200 for some strange reason (I think thats what it was, I know it started with 11)
You might check over at the manufactures web site for the product and see if there is something your missing... :shrug:
