I have a 99 24 valve auto, when you put it in drive, reverse, or park... there is a big clank. I'm told it's my rear rack/pinion setup. Does anyone have a write up on replacing it and best place to order parts??? I'm more than savy under the hood but this rear end situation is a little foreign to me.Thanks
  • Replies 2
Popular Days
you mean ring and pinioncheck your drive shaft u-joints first bad u-joints will clunk going into gear if it is the rear diff pull the cover and have a look if the crown or pinion still have all there teeth if so just reset your lash and off you go
  • Current Donation Goals
    • Raised $20
